Key Check Mode Problems on MZ-r700
Kotarou
I'm having some trouble with my unit, When entering in the Key CHeck Mode and testing all keys on the Unit, the display appears SET OK 0E 0 00. But when I try testing all key on the remote, it does not appear RMC OK ** 0 00 , Is there something wrong with my remote or unit?
I'v noticed when pushing the pause(Caps) key on remote, the display appears:
rPAUSE AB 0 04 or rPAUSE AA 0 04, AA is changing to AB. And the EDIT key on the remote appears: rDISP 66 0 04 or rDISP 66 0 04, is the same as the pause key. The others keys i guess they are right like PLAY that displays rPLAY BD 0 04 (the BD is Fixed not changing like pause and edit). Can anyone help me?
My unit is Hacked 700>900 with no problems
I just noticed this problem when i tried to use the R55 remote in my unit, and there was no BackLight and when pressing any key, the display on Remote, Blinked.
Can anyone help me? I guess it's some resistor or something in my Unit, but is just a GuesS!
sorry for my bad english!!!
Guest Anonymous
I'v Tried all again without the Hack, but i'm still having problems.
Anyone who have a R700 could tell me if appears RMC OK on display, on Key check mode? (to enter in the key check mode, just enter in the SERVICE MODE and press T MARK, then just press the keys to test)
I'forgot to login, i wrote this....
This takes me back...
I remember reading two other posts by two different users, who claim this happened after they did the R900 hack on their R700s. I think both fixed the problem by un-hacking their units. The same happened when they used the R900 remote. Perhaps un-hack the R700 and try the R700 remote, instead of the R50's.
Other than that, I can't help much, as I am unfamiliar with Sony portable's service mode...
